- Joined
- Sep 26, 2010
- Messages
- 9,807
It has been said here at various times that increased wear rates happen after an oil change. While I can potentially see that happening if the oil brand/type was changed or if there was a reformulation of the oil currently being used that happened between the oil changes (like changing additive packs or API designation), but with everything else remaining the same, I wonder if wear rates really do increase after an oil change.
Components of the additive pack linger past the OC when the new oil does not have that component (titanium vs. moly or sodium as an example). Ergo, logically thinking why would there not be remnants of higher concentrations of wear metals which are in the oil that remains in the engine after an oil change and it levels off as the new oil picks up new wear metals.
It would also seem the only way to know if my hypothesis has any merit to it would be the completely clean the engine internals between OCs as part of a controlled test (which may not be feasible), but it would eliminate some variables.
Here Mobil Super 5000 has sodium as part of its additive pack, but Kendall does not (as far as I know), yet you see sodium showing in the Kendall UOAs after the MS5K was used. If this is true and it appears to be, what is stopping wear metals from doing the same?
What are your thoughts?
