0w20 is recommended, but will using 0w30-40 or 5w40 be better?
-Would using other than 0w20 void warranty?
There are tons and tons of thread that go over this.
No, I meant months. But it's mostly a joke. Unless you own one of the recent years with issues.I’m pretty sure you mean 3 years for the battery not months right![]()
My 2006 Silverado w/ a Gen III 5.3L is turning over 200K miles next week. Still love it. It has very little rust given we really don't use salt up here. Though, I will be replacing rocker panels, cab corners, and other minor bits -- repainting to keep it looking good and road worthy in the near future. The frame is practically rust-free -- I personally pressure wash the undercarriage during the spring and fall periods and don't mind getting a bit wet.Same could be said for the trouble prone old Honda Accord AT IIRC.
Unless it's GOOD mid-sixies American iron, I don't get why anyone would want to keep something 250K +
We sure haven't come across any keepers in the past 50++ cars
Agree. Being a thickie, I'd lean towards a xW-30 while the engine is newer, and a 0W-40 later in the engine's life.Depending on what the oil spec is for warranty I would run a 0w20 or 5w30 from any brand of your choice and change on time with an oem or napa filter![]()
No, sorry. That was back when my '13 Outback was new.Any links to those threads about the Subaru’s break-in additives
OP don’t listen to this old wives tale. There’s literally millions of cars out there that run the factory oil to the full oci to no ill effect. If the OM isn’t telling you to dump it early, don’t.Congrats on your new Subaru.
Run a full synthetic. There is no reason not to. Changing the break in oil is a personal decision. I do mine around the 1000 mile mark but many others run a full OCI on the factory oil. I feel better getting the break in metals out early on. It also gives you the chance to explore your vehicle understand get familiar with things. Use any major brand of oil according to the owners manual.
Drive it sensibly and you will get many years and miles of service.
You should have a "Getting Started Guide" in your black pouch in the glove compartment. It basically says to be easy on it for the first 1000 miles. You should also have a "Warrant and maintenance" booklet. Oil change intervals are 6000 miles. Under severe conditions 3000 miles. Severe conditions are repeated short distance driving.I’m trying to do the break-in properly by varying the speeds and going through all the gears. Yesterday I forgot leaving the light I was in manual 1st gear & accidentally revved the motor to 5k rpmAll seems all ok though. I read somewhere I should keep it under 4k during break-in
Changing the oil early one time isn't OCD. Doing it at every oil change (1000 miles or whatever) would be.OP don’t listen to this old wives tale. There’s literally millions of cars out there that run the factory oil to the full oci to no ill effect. If the OM isn’t telling you to dump it early, don’t.
If this isn’t ocd-like behavior, I dunno what is.
Yeah, I kind of regret not switching to it earlier with the Outback, the 5W30 does make it noticeably quieter. I'm sure most dealerships wouldn't care what oil they put in unless its 20W50... I recently drove a new Legacy loaner with the 2.5DI motor and it seemed a touch louder than my car on start up.Run 5w-30. The Subaru will prefer it
I'm running conventional 10w-40 in my 2.0 Impreza. Yeah it lost a little pep but it's quiet now.Yeah, I kind of regret not switching to it earlier with the Outback, the 5W30 does make it noticeably quieter. I'm sure most dealerships wouldn't care what oil they put in unless its 20W50... I recently drove a new Legacy loaner with the 2.5DI motor and it seemed a touch louder than my car on start up.
