We finally got some... 0W-8.
The car makers using 0w-8 and16 don’t allow for the heavier grades in the USA though like the Ford engine does. Toyota says can use 0 20 but change back to 0 16 at next change or as soon as possible, not sure of exact wording.
They aren't allowed to under CAFE, if your vehicle's CAFE rating is done on a 0W-8, that's the only grade you can spec. That's why the grade charts vanished from manuals.
And keep in mind, the Ford situation was the same engine in two different trims of the car. Regular GT? 5W-20, Track Pack GT? 5W-50. Exact same engine, different trim.
To finish, for me, I would like to go back to oil pressure. I know splash lube is an oiling mechanism. You are saying 0 psi is still ok. I think we all know 1 psi is not going to work well in an engine. There will be bearing knock. Psi is good for the pistons if there jets but otherwise I think it’s splash. I know I read somewhere decades ago oil pressure in the bearing separates the parts. The hydrodynamic pumping still functions, but also there is considerable oil pressure in the narrow bearing opening. At 50 psi at gauge port I am guessing the main bearing pressure could be ten times that. Or is gauge port pressure due to main bearing resistance? It’s not clear about the oil pressure raising the psrts. Nothing changes, I still will go by the cap, although I think I was in the heavier oil brigade because of start up rattle.
Why do bearings knock? It's because the clearances have opened up to the point that they make noise, it's not a function of oil pressure, oil pressure is an artifact of resistance to flow, when you have bearings that are worn out, the wider clearances allow more leakage which means less resistance to flow which means lower oil pressure. It's like the difference in running 20W-50 vs 5W-20, you are going to see WAY more oil pressure with the 20W-50 (perhaps to the point of putting the pump on the relief) because it leaks less due to being heavier, which creates more system backpressure, which you see as oil pressure on the gauge.
Some of the very old antique boats I had the pleasure of being around were gravity lubricated. There was a big glass bowl above the engine with copper lines running everywhere to lubricate things, including the bearings. All of the leakage ended up in a giant brass drip pan below the engine that you had to periodically empty.
@Shannow who is a mechanical engineer and specializes in bearing design, has written on this subject extensively. It would be quite beneficial to you, and greatly improve your understanding, to go back and read some of his material on this.
I know using precise cone bearing lathes, plain bearings, oil viscosity and how much heat generated is very noticeable. The whole headstock will get hot with a thicker oil, versus not with a thin oil. First hand experience. The graph is extreme in that10w 60 and 0w 20 are far apart, and what is the temperature.
Put some much thinner oil in those come bearings and see how long they last. In journal bearings, a thinner oil will result in a smaller MOFT, which if you do the calculation of the shear rate inside the MOFT it actually creates more shear rate than if the MOFT is thicker. More shear rate also means more temperature increase, so going thinner isn't saving much temperature increase overall. Like I said in a previous post, a YT guy who tracked his car a lot though he would just run the 5W-20, and after a few track sessions he inspected the rod bearings and they were extremely worn. The oil temps might have been 10F lower, but the MOFT broke down to cause excessive bearing wear. If he would have ran a thicker oil they would have survived better.
Here's a study that showed going from 0W-20 to 0W-30 only increased the bearing temperature around 1.5C. Using the 0W-30 is still going to provide more MOFT even if it's running a bit hotter. High performance engine makers aren't going to say to use thicker oil for track use if it was going to go backwards in engine protection.
It could be Toyota supplies engines with tighter bearing clearances for where they recommend 0w 8 or 16. Like the USA, it’s a big supply of engines and it could be they do that. With the benefit of less friction in the bearings for maximizing efficiency.
Maybe someone has the factory service manual so they could look it up. The main reason they survive on 0W-8 or 0W-16 isn't because they have tighter clearance, it's probably because they are wider and have more surface area to support the loads. If they are too tight, they will over heat and destroy themselves. Journal bearings being too tight is a killer since the MOFT temperature skyrockets and the viscosity in the MOFT goes so low that the bearing starts destroying itself.
A Toyota engine may have tighter tolerances and clearances than the Coyote, which seems more like old times clearance ranges. Probably Ford has equal capability to any company, if they so choose, to make tighter tolerances and less clearance. Like .001” +/- .0002”or something. Of course an engine goes from cold to hot so everything expands and contracts.
Look at the bearing clearances on the XSR900 I posted in that thread I linked to in an earlier post. Here's the snip:
A good example that shows that engine parts made as tight as possible don't really care about the oil viscosity are motorcycle engines that rev to 11,000+ RPM using 20W-50 oils. This is also seen in OMs for the same car engines used in different countries that don't abide by CAFE and show a whole range of specified oil viscosity in the OMs. The minimum service manual specs for my XSR900 shows clearances as low as follows, yet Yamaha specs oil viscosity all the way up to 20W-50:
Rod Big End: 0.001 in
Crankshaft: 0.0006 in
Camshaft: 0.001 in
Piston to Cylinder: 0.0004 in
Piston Pin: 0.0003 in
The bottom line is that thicker oil gives more MOFT in looser bearings than thinner oil does, but thicker oil also gives more MOFT
even in tighter bearings. Bearings with more clearance are more sensitive to thinner oil than tighter bearings are to thicker oil. As @OVERKILL pointed out, that's why they survive extremely cold start-ups when all oil is very thick. Running thicker oil in tighter bearings isn't going to cause any problems, but running thinner oil in looser bearings certainly could cause problems.
You missed the premise of my post. I was saying that a journal bearing does no rely on the oil pressure to support itself. All it needs is an adequate supply of oil to at least make up for the side leakage. Many journal bearings in industry have been simply gravity fed, like this.
Obviously, it would be impractical for a modern engine. @OVERKILL gave an example above of an engine that actually used a gravity fed oiling system. The pressure inside the MOFT wedge is in the thousands of PSI due to its natural formation, so adding 50 or 60 PSI from the pump on top of that isn't going to matter. The pressure from the pump is simply to supply an adequate oil volume to all force fed parts within an engine. There were splash oiling systems in engines before they started using PD oil pumps. I'm sure you've seen this video since you've been here since the "goodtimes" days. This video is old, but all the physics of oil film and viscosity will never change.
Feed oil pressure does not "support" journal bearings. How is 50 PSI gauge at the inlet of the journal bearing going to create 10 times that pressure simply due to the supply pressure? Do some more self study on journal bearings - there's endless info on the 'net. As I said above, even if the oil is simply supplied under gravity, the natural action of the rotating journal bearing draws in the oil and creates the supporting wedge which could have a pressure of thousands of PSI in the MOFT. The oil pressure you see on the dash is simply the resistance seen from the PD pump trying to force oil volume to all parts of the oiling system. If an adequate supply of oil volume is delivered to moving parts, then there is adequate lubrication as long as the viscosity is adequate enough. You could have adequate supply oil volume, but if the viscosity is too thin, it could cause problems. There needs to be both adequate supply volume and viscosity.
I was writing if the oil pressure is one psi with perfect clearances. Not clearance makes it one psi. Maybe the engineers can try it out on their engines.
This is all true for most bearings, but not for rod bearings. Rod bearings have a minimum oil pressure requirement to receive any flow at all. This is because the oiling supply is within the rotating crankshaft, and is affected by centrifugal forces. This minimum pressure increases quadratically with engine speed, and when oil pressure drops below this value, flow is completely interrupted, and MOFT drops to zero.
Here's an example of this, from SAE 860229 - Lubricant Flow to Connecting Rod Bearings Through a Rotating Crankshaft
This doesn't exactly apply to the engine in the video because those bearings are supplied by oil jets, and not from passages within a rotating crankshaft. Likewise, main bearings and cam bearings in an engine will maintain a non-zero oil flow and MOFT at very low supply pressures. This is why they don't tend to experience sudden and catastrophic damage, as often happens with rod bearings.
Most cases of rapid rod bearing wear are probably due to insufficient oil pressure reducing MOFT to zero, and not simply from low MOFT.
Of course, a thinner oil grade can contribute to lower oil pressure, reducing the safety margin. However, on most engines, the oil pump will be in pressure relief at high rpm, which helps maintain adequate oil pressure as the viscosity drops. At lower rpm, oil pressure is less of a concern.
Of course it may not work that well for rod bearings on reciprocating rods on a crankshaft. Again, the whole point (and context) of my example of that journal bearings can operate on just gravity fed oil supply was to emphasize that the oil film wedge that puts journal bearing in hydrodynamic lubrication and supports them is not due to the oil pressure, as someone thought. What actually supports them is simply the oil wedge that naturally forms inside a rotating bearing as long as the oil supply is getting inside the bearing. And plenty of journal bearings all around the world in industry have been simply gravity fed an oil supply. The premise is: Get oil into the journal bearing and it will create the supporting oil wedge if the rotational speed and viscosity is adequate enough to do so.
I'd think the viscosity being too low has more to do with it. Keep in mind that the lower the MOFT goes due to thinner oil, the higher the shear rate becomes in the MOFT wedge, and the higher the wedge temperature becomes due to the shearing factor. That somewhat cancels out the heat that would be generated from shearing a thicker oil with a larger MOFT (less shear rate), and why the temperature rise isn't that much different between the viscosity used. When the dust settles, thicker oil is going to always give more MOFT with all other factors being constant.
Any good engine designer should have put plenty of head room into the PD design and all oil flow paths to supply adequate oil volume to the bearings (and all other force fed components) at redline and not be on the ragged edge of disaster. If not, then it's an oiling system design problem with respect to providing all bearings with an adequate oil supply throughout the entire RPM range all the way to redline. Running a thicker oil to achieve more oil pressure at the journal bearing inlet holes to ensure proper supply flow is another positive aspect of running thicker oil.
It's the oil film that's providing the lubrication (like the 1937 film shows) ... as long as the proper oil volume is supplied (by flow via the pressure in a force fed system, or by splash lubrication), and the viscosity is adequate enough to provide a proper MOFT to keep moving parts separated. Of course the oil's AW/AF tribofilm needs to also be robust enough (as well as the materials and coatings used in the engine components) to mitigate wear when the MOFT is minimal or zero in the mixed and boundary lubrication realms.
No teaching certificates up in here. Everyone learned what they know at sometime. There is nothing wrong with presenting ideas if it is a place to learn. If it’s a cage match, maybe the site name should be changed to lets fight over who is right guy.
Cafe no Cafe, doesn’t matter what the reason, Toyota, if they designed the bearings tighter for thin oils, then they don’t put thicker oils in the manual. It looks like that is the case to me. More data needed.
But it's been shown many times that the same engines used in different countries do put other oil viscosities in the owner's manual. Snap shots of the OMs have been posted in almost every thread like this (see link below - tight bearing clearance is not "designed" just for thin oil). As pointed out earlier, tighter bearings can tolerate thicker oil, while looser bearings can't tolerate thinner oil as well.
I'd bet the bearing clearance in those 0W-8 and 0W-16 specified oil Toyota engines are not any tighter than any other modern engine with specified thicker oil. You can only go so tight with bearing clearance even with oil that thin. Journal bearings will over heat and smoke themselves pretty fast if the clearance is too tight causing bearing over heating regardless of the oil viscosity, and them being not much below 0.001 is about as tight as any journal bearing will be. The XSR900 crank bearing clearance can be as small as 0.0006 inch per the service manual as mentioned before, and yet Yamaha says you can run 20W-50 in that engine.
Go read this whole thread if you want more info.
Are you making stuff up with every post? Because you certainly are not listening to nor comprehending any of the technical information that is being presented in this thread.
It absolutely matters that CAFE is the reason. If you can't spec other viscosities, you only get the one the vehicle was qualified on, it's a pretty simple concept.
But they DO put thicker oils in the manual in markets that don't have CAFE, like Australia. Just like @ZeeOSix posted, here are the oil spec pages for the 2023 Corolla from Australia:
Same manual (note the same engine code) for North America:
So the same engine spec's everything from 0W-8 (CAFE land!) to 5W-30/10W-30 (Australia).
View attachment 250995.
Toyota, IF….., more data needed.
