We Are Obsessed But Does It Really Matter
Piston skirt. Who needs a piston skirt. Ferrari 812 Superfast piston:
Piston top:
Ali
Also, piston skirt length is a factor in keeping the piston rocking in the cylinder to a minimum. Shorter stroke engines can use shorter skirt pistons.
Couldn't short-skirt pistons be used on long-stroke engines?
Why not use almost skirtless pistons in more applications?
Short stroke with a longish rod has very little side loading/scrubbing, while a long stroke has a lot of it, and tries to rock the piston a lot.
Of course the taller the piston and longer the skirt, the more friction you have in the bores, which is why attempts to shorten them as much as possible are made.
Hey ripcord... Sometimes though... A pretty, pretty lady wearing tight jeans is a great option as well. I was in Food Lion grocery store about 3 weeks ago and this super pretty and tall I mean darn near my height I'm 6 ft 2 and she had jeans on and she was stunning.... I mean super pretty.
I had thought there was a Federal law not allowing good looking women in Food Lion grocery stores... I guess it may have been repealed recently. :LOL:
Especially durable were the small block Fords of 221 - 260 - & 289 cubic inch displacements. They would normally last 400,000 to 500,000 miles before any internal engine work, and if they didn’t the dealership got an earful. Also very durable we’re the Ford I-6 200 cubic inch models. Excellent lubrication design and bearing placements on all of the above.
Mine wasn't reliable or durable. My Mercury Comet 289 V8 needed a valve job at about 60,000 miles and was a heavy oil burner by 80,000 miles.
Aside from the squeaking front end and the smoking/oil burning I really liked that car. But it left me on the road twice (probably a failing coil) and I gave up on it.
Over all these years I have never heard of anybody I know that parted with a car because the engine wore out, even with many hundreds of thousands of miles. The car just had more things go wrong than it was worth but not a worn engine per say.
I gave up on my '65 Comet 289 V8 largely because of the engine. It needed a valve job at about 60,000 miles and was a smoking oil burner by 80,000 miles. The final indignity was it left me on the road twice probably due to a failing ignition coil.
At some point (a failing engine) you cut your losses. I did and it was largely because that engine was on the way out.
For the record, I took good care of it too. Regular oil changes (10W-20 in the winter, 10w30 in the summer), air filter replaced regularly, a tune up annually (new points and plugs, timing checked), coolant replaced annually, carburetor rebuilt once.
The good news is I learned a lot about auto maintenance and repairs.
Edit - That should be 5W-20 oil in winter.
At some point (a failing engine) you cut your losses. I did and it was largely because that engine was on the way out……”
Sorry to hear your experiences were so negative.
Due to my after school job at uncle’s repair / race shop, and my parents having a cafe across the street from the Ford, Chevy, and Plymouth dealerships, where I spent all my free time, I got a birds eye view of the sales & repair side of the 1950’s to 1970’s car business in middle America. There were some poor engineering here and there, but the Ford small blocks were among the most durable, My parents took their Ford Fairlane 500 in to the dealership for a tune up every 20,000 miles, whether it needed it or not. Oil changes were done at the neighborhood Phillips 66 station every 2,500 to 3,000 miles. When the car was traded in in the mid 1970’s it had over 300,000 miles on it. Visiting relatives on the west coast accounted for most of that
Photo from in front of Donges Ford, Bartlesville Oklahoma, circa fall ‘65 or spring ‘66. The 1966 models were on sale.
Z
It does matter. I think using a quality oil along with proper OCI'S is key. Many folks say 3k is too short given today's oil and motor technology but, any quality synthetic is cheap vs engine replacement especially when you buy from Wal-Mart. Knock on wood I haven't had any oil related failures doing this for the past nearly 3 decades. To say brand x will make your motor last this much longer vs brand y you are splitting hairs as formulations change all the time. Some brands more than others but most overlook the oil filter which is just as important too because that catches and holds the harmful dirt. Can't tell you how many times folks will buy a boutique oil like RP, Redline, Amsoil and throw a 3 buck Supertech oil filter on. Just my two.
The engine will out last the rest of the drive line doing proper oil changes and using the Supertech oil filters. The air filter is the most important filter as far as engine wear.
Change oil filter and severe service OCI is there too… Forget that 20,000 mile claim.
