The CR-V transmission has a drip plug to verify fluid level, just like my BMW motorcycle, only the drip plug is separate from the fill opening on the Honda. Strange setup. The cynic in me thinks that these quirks are to get folks into the dealerships.
Friday night fish fry? haha. Anthony's gnocchi and veal is the best!
I would go with the drip plug. If you can, get it level and warm up the engine, run it through the gears a few times then open the drip plug. If there isn't any fluid coming out, add fluid from the fill plug until it trickles out. Similiar to a transfer case or your BMW cycle. Once it starts flowing out I would close it up, go through the gears again a few times and open it once more. The fluid should just be trickling out,not a steady flow.
Well I went the drip plug route and it would only hold another 3 ounces before the fluid trickled out of the hole. Good Enough! So the 4.5 quarts specified in the manual seems fairly accurate for a fluid change refill after all. Going forward it will be super easy and basically foolproof to use this method. Thanks to all who made constructive suggestions! Your help is greatly appreciated.
Yes! The Western NY area's Friday Fish Fry is just one of many great traditions and experiences to be enjoyed while living in this special area.
