Thought I'd break up the monotony of the usual "I overfilled my oil by 100 mL. Should I throw away the car and buy another?" threadsWeirdest thread ever.
Was wondering if waxing the inside of the bowl would help with the sticking problem. Any of you guys tried this?
Depends on the toilet bowl cleaner. Some are bleach based and highly alkaline. Not sure of the "blue" (or other color) type. I've heard of recommendations to not use those because it may increase the viscosity of the tank water, which will then affect the power of the flush. In any case they have problems because they can damage the fill valve, flapper, and flush valve. They're pretty bad for the seals.So exactly how do Toilet bowl cleaners work?
I thought they were acidic, but not as much as drain cleaners?
But they can't damage the factory "glaze" that low flow china bowls depend on....
But to be honest, the market has a "sheet load" of bad toilet designs. That is why I stick with Toto toilets. ...and I know the POTUS did sign a bill/law/order allowing more water usage for dishwashers,washing machines, and the sale of incandescent light bulbs. I do not know if toilets were included.
the word you're looking for is Bowl... bowel is where the poo comes from....you're basically telling him to stick his fingers up his keister...Turn off the valve, flush the toilet, let the bowel dry and rub inside of the bowel with your bare fingers. The natural oil from your skin will put down a micro layer of lubrication.
Yes it is.
Maybe someone needs to contact "Project Farm" and get him to make some head to head tests of best toilet bowl sealer lol.
Some mix Dawn with vinegar to break up calcium film on the shower wallsGet a spray bottle. Fill it with 1/5 Dawn Ultra and 4/5 water. Spray the offensive area with the solution. Wait 1-7 minutes and then flush. Problem solved.
Collonite 845. Like a thick shake. Umm good!Eat carnuba wax, lays down it's own protection and it makes the water on your butt bead up - so I'm told.
This thread is going down the … no, wait, that’s where it started LoLEat carnuba wax, lays down it's own protection and it makes the water on your butt bead up - so I'm told.
