Well,hours ago,I installed a new ac Delco alternator. Removed the tensioner pulley,too across bottom bolt. I noted,under car,looked like water,under oil filter. It was hard too tell,if it was actually water,or coolant mighta smelled like it,but my hands dirty from alternator...i dunno.no visible leaks from water pump housing.The hose these engines notorious for,plastic is not broken. I had new water pump installed 4 years ago. About 30,000 miles on it.
Under car,Thier is,tiny amount of green coolant dripping from bottom of oil filter ran my car a bit ,under car,no more drive a good 1-3 miles,3 times,no more leaks.
So...think it's a warning? Water pump outlet hole..gasket failing?
