billt460
Thread starter
Good point. I always kill the breaker to the water heater whenever I shut off the water to do a plumbing project. When you start opening faucets It's easy to create a back siphon condition and have a situation where you might expose the top heating element.That is an invaluable precaution that should be taken when someone goes on an extended vacation. Just be sure that the electrical/gas supply is shut off on the water heater so you don't risk damaging the element/burner.
If that happens you'll be installing a new water heater in addition to whatever else you were working on.
Turning off the cold water supply valve to the water heater helps to prevent this as well.
