I replaced my original in 2007 (11 years old) because it was making "bubbling" sounds due to sediment build up. That also caused it to be less than efficient at heating the water. The one I bought was Home Depot's "best" gas water heater (GE branded, but made by Rheem). I have tried draining sediment, but I never get anything substantial out of it. I installed a new shutoff valve (ball type) due to the fact that the cheap Chinese valve the builder used would not shut off the water flow. I then opened up the biggest faucet I could find in the house (the garden tub) and drained some water. Nothing but clean water came out.
I have seen, in the past, the drain valves not seal completely after draining if sediment gets stuck in them. I always cap my drain valves just in case.
I purchased a new anode rod last year with the intention of changing it. I tried my electric impact wrench and a big breaker bar. All I succeeded in doing was shifting the entire, full unit a couple of inches. The darn thing won't budge. Mine is on a platform in the garage and I have confirmed that the garage floor slopes toward the overhead door. I see the heater every time I pull into the garage so I would be able to catch any leaks very quickly.
If anyone has any tips on how to remove the original anode rod I welcome them, btw!
