Originally Posted by Wolf359
Originally Posted by dishdude
I keep going back and forth on anode replacement, I'm thinking replacing the entire tank every 10 years is the way to go.
Isn't that the equivalent of changing the engine rather than changing the oil?
A water heater is a lot less than an engine, and the life span isn't much longer than 10 years. Why bother with draining crud that won't likely drain anyway and dealing with an anode rod that might be impossible to remove to extend the life to what? 15 years?
I dunno, maybe saving $400+? I usually have a cheap indy or a handyman replace a hot water heater, there was a thread about this earlier and I think the total was over $1000+ from a licensed plumber. If you get 15 years instead of 6-8 years out of water heater that's a nice savings. For me, I have over 10+ water heaters so not having to replace one or two every year adds up.
Well I only have one, so just planning to replace it at the 10 year mark makes sense.
