Originally Posted By: alcyon
Cool, thanks for the peace of mind, I am still old school though. I will try to keep oil temps lower for this oil. The rise in oil pressure seems pretty good though. I am able to get 50PSI at 2500rpm at 90C bulk oil temp. with 5W-40 I get 60psi at same parameters.
I wonder if the Pennzoil conventional straight 30 will yield noticeably higher oil pressure.
The HTHS viscosity determines the PSI, so if I were you I'd just drive normally unless the pressure at idle drops to the 5 psi region, but it would need to get a lot warmer than 97°C to see that.
