K knerml Joined Apr 5, 2005 Messages 752 Location Phoenix Nov 15, 2018 #1 Is Super Tech synthetic 2-stoke oil mixed with Stabil suitable for an Echo 58cc leaf blower, or should I stick with Echo Power Blend? Using 50:1 mix. Last edited: Nov 15, 2018
D dblshock Joined Apr 24, 2007 Messages 4,038 Location WI. Nov 15, 2018 #2 yes, skip the Stabil though. been using ST for years including 4cyl. outboard.
J JLawrence08648 Joined Jan 20, 2017 Messages 922 Location NJ Nov 15, 2018 #3 I use it but at a 40:1 mix because I have other equipment that calls for 40:1 and I prefer a slightly richer mixture.
G gman2304 Joined Aug 11, 2011 Messages 7,216 Location N.C. Nov 15, 2018 #4 FWIW, I've used the Echo power blend for years with no problems. Why are you considering the ST, price?
K knerml Thread starter Joined Apr 5, 2005 Messages 752 Location Phoenix Nov 15, 2018 #5 Price and availability. 1/2 the price.
H hatt Joined Jan 3, 2012 Messages 6,023 Location Florida Nov 15, 2018 #6 Originally Posted by knerml Price and availability. 1/2 the price. I doubt you're using enough to make either of those things matter.
S SwampSurvivor Joined Apr 9, 2008 Messages 17,764 Location Central NY Nov 15, 2018 #7 I have been using the supertech synthetic 2 stroke oil in my small generator, weed wacker and my parents' 2 stroke snowblower for a while now. Works great!
Revving2Redline Joined Feb 25, 2014 Messages 8,412 Location Kansas (316) Nov 15, 2018 #9 Stabil seems to make a skin over fuel and its yesterday. Try non ethanol fuel or top tier fuel instead.
J JLawrence08648 Joined Jan 20, 2017 Messages 922 Location NJ Nov 15, 2018 #10 Originally Posted by CT8 What does the Stabil do? Preserves the fuel from going bad, makes it last longer, not going stale, helps prevent varnish from forming.
SubieRubyRoo Joined May 15, 2012 Messages 11,667 Location The land of USA-made Subies! Nov 15, 2018 #11 How?
Rand Joined Aug 20, 2003 Messages 25,389 Location NE,Ohio Nov 15, 2018 #12 use echo red armor.. it has fuel stabilizer in it too $10 worth lasts me years.
K knerml Thread starter Joined Apr 5, 2005 Messages 752 Location Phoenix Nov 16, 2018 #13 Found a good price for PowerBlend XTended Life Oil on Amazon. All set.
S slomo Joined Aug 24, 2013 Messages 524 Location Oklahoma Nov 16, 2018 #14 Originally Posted by JLawrence08648 I use it but at a 40:1 mix because I have other equipment that calls for 40:1 and I prefer a slightly richer mixture. Why stop at 40:1? Just go with maximum protection at 1:1. slomo
S SwampSurvivor Joined Apr 9, 2008 Messages 17,764 Location Central NY Nov 19, 2018 #15 Oddly enough, I go the other way. I usually mix at 50:1 for everything, even the 40:1 2 cycle engines.
