Waiting for P0420 to clear
Oahu, Hawaii
Check engine light on, scanned a P0420 on my toyota truck. Recently happened when I started filling up with questionable gas (the one with horror stories - but its cheaper!) Will the light clear itself if I start running it with top-tier gas or should I just clear it out manually?
Your catalytic converter is dying. Disconnect the battery and take it for a nice drive
Its the programming. Toyotas are set to throw a P0420 CEL at 95% efficiency. Means the cats basically still good. Will still pass emissions. Clearing the code wont do anything other than make you feel good for a while. The answer is clean the cat, replace the cat, or fool the cat.
Not only Toyotas; as far as I know Hondas and Nissans are the same.
But people have to find it first hand. There is no point in telling the world' nobody listens.
- Vikas
