OVERKILL
$100 Site Donor 2021
Indeed it does I was simply looking in the wrong place.
So would this be better to use than the Mobil 1 0w40? While I was at the store I saw the Mobil 1 ESP 5W40. Maybe for my TSI engine it would be a good choice though is not VW approved.
Jeff
Define "better" ? GC has proven to be a shear-stable lubricant and has performed well in application from what I've heard. However, Mobil 1 0w-40 is a more modern, high VI formula that in its current SN iteration is also proving to be a shear stable and excellent performing product.
Better as is ability to stable over its use. I have Mobil 1 in my car now and will see.i do know Pennzoil Ultra 5w40 sheared to a 30w in 3000 miles will see if the Mobil 1 does the same thing. if it does I might as well usea 30w that at least stays consistent throughout its use.. Or are we assuming the Mobil 1 is VI and is a better choice because of that. Do we even know if Mobil 1 is still VI after its reformulation?
Jeff
VI = Viscosity Index
I think you are thinking PAO? The new (SN) Mobil 1 0w-40 has a lot of (shear stable) VISOM as part of its base, which is a GIII+ product. I'm interested to see how it holds up in your application. You can check out my used oil analysis of the SM formula to see how it held up in my (fuel diluting like crazy) one.
Jeff
Jeff
