I'm getting an evap code error on my daughter's 2009 VW Rabbit. I thought I'd start with replacing be the gas cap as an easy starting point.
I picked up a cap from the parts store, got home and got it out, but it clearly isn't the same one. I took it back, the parts guys (at Oreilly) couldn't figure out which cap it uses. They said they didn't remember ever seeing anything that even looked similar. They ran the part number and came up negative as well.
I found the one I think I need online, but it shows up under slightly different part numbers.
The one on the car now is 1J0201553N. The ones I find online have different numbers, like - 5C0201550E.
They look the same. I've checked several online parts houses and they all come back with different numbers when I put in the year/make/model.
Does anyone know if any of parts # for this style VW cap will interchange?
