Pennzoil Platinum Euro doesn't show vwspecCan you find Pennzoil Platinum Euro 5w40 or Mobil 1 5w40
Is Mobil 1 ESP x2 0w20 available anywhere
From what I can tell both Pennzoil says it's VW 502 on the jug and their website, and it's on a VW list I found.Pennzoil Platinum Euro doesn't show vwspec
No Mobil 5w40 here
No, those are completely different approvals and are not compatible. Even VAG warns you.Ok thx . For the car that takes 502 . Is it worth or advisable changing to a 507 or 508
Which 508 do they haveCanadian Tire usually carries the 508.00/509.00. But, it shows that they are out of stock. The best place to buy it is from VW, Audi or Skoda dealerships.
502.00 should be fairly easy to find. Walmart, Canadian Tire and etc.
Can you tell us what vehicles are in question?I need
5w40 for vw 502 00 and 0w20 for vw 508 00
Which oils meet this in canada and or which are recommended . As I don't believe castrol of this spec is carried here .
2020 audi q5 0w20Can you tell us what vehicles are in question?
Check whether 2020 Q5 has the option of VW 5004/507.00 in the manual.2020 audi q5 0w20
2017 s5 5w40
In reality, in both, you can use VW504.00/507.00
If 2020 has only VW508.00/509.00 option, use whatever approved.
You have numerous topics here that deal with those oils.Our weather here fluctuates. From winter of -20 to 42 degress Celsius in summmer so should i stick with 5w40?
Whats the difference with all these oils .
Which don't burn off easily and or clean the best
How do
Motul 8100 xcess vs 6100?
Then liqui Moly has premium, high-tech and molygen?
Compare to castrol edge ?
VW is known to have one thing in the manual and another under the hood.View attachment 52066
The manual is ever so helpful (that's totttalllly not sarcasm) it tells you to check the sticker in the engine bay.
I wonder if the government is cracking down more on what languange you use in the manual when recommending oils, I noticed in a new Hyundai manual that the only oils they had listed were 0w20 for a N/A model and 0w30 for the TGDI model of the car whereas Hyundai until relatively recently used to tell you to use anything from 5w30 to 20w-50 in turbo cars.VW is known to have one thing in the manual and another under the hood.
Ever so helpful manual says Castrol Edge Professional but VW source its oils now from Mobil 1. So, there is that.
What?Do u remember riff hand which don't burn off ez
