- Joined
- Oct 14, 2023
- Messages
- 228
It’s a Short. Above average fascinating, in my estimation:
Can't be worse than the GM 4 cylinders as of late .. can it?Heard a tiguan 1.5 start at work the other day. The chain noise was cringe worthy.
Mine (1.5T in a Malibu) is silent as well, even with the engine cover removed. 14500 miles on the odo.I think it was due a chain replacement. The only GM 4 cylinder I've heard is my own, and the chain is silent. But then the car is only a year old.
The EA211 1.5 has a belt and not a chain.Heard a tiguan 1.5 start at work the other day. The chain noise was cringe worthy.
The 1.5 doesn't have a chain, it has a belt. The only chain in the engine is for the oil pump. If you're in the US, the Tiguan is the EA888 2.0L which does have a chain.Heard a tiguan 1.5 start at work the other day. The chain noise was cringe worthy.
This is untrue, the 1.5 also has a dry timing belt. Source: I have had two of them. here is a teardown of one for the head gasket replacement. (Some 2022s had an issue leaking coolant from the large cavity on the back which cools the built-in exhaust manifold, not an internal head gasket failure)I think it was due a chain replacement. The only GM 4 cylinder I've heard is my own, and the chain is silent. But then the car is only a year old.
The 1.4 had a dry timing belt, so that wouldn't make chain noise. The latest 1.5 tsi have a wet timing belt.
Personally, I think the 1.5 is a big upgrade from the 1.4 in several ways. First, it still has variable displacement but instead of only switching the cam lobes for the center two cylinders it actually changes profile for all 4, which gives the two outer operating cylinders a more effective/efficient cam profile for running in 2 cylinder mode. Also, the active oil separator should help greatly with the intake valve deposits. The 1.4 wasn't very known for those but the 1.5 should be even better. The 1.5 also moved to an all-metal water pump housing vs plastic on the 1.4, I guess VW finally learned from that particular mistake. Some people think plasma coated cylinder is a downgrade because they can't be rebuilt. But they are more durable than cast iron, and have lower friction, so they should need to be rebuilt less in the first place. Not that many people are actually gonna be rebuilding these, if they end up being like the 1.4s the price on a used one is pretty low because they aren't very failure-prone.
I went by this video, there's oil inside the timing cover
