That is an instant red flag to me......The Bosch were supposed to be .043 but were .015-.025 .............
We have all seen it. Some engines don't like some plug brands.
Yesterday I removed 4 plugs from an Audi. The ones I removed were NGK double platinums and were put in at the Audi factory.
I installed 4 new Bosch double platinums. I always check the gap very carefully as to not damage the plugs. Don't force a gap tool to fit.
The Bosch were supposed to be .043 but were .015-.025 so I used needle nose plyers to adjust the gaps to spec.
Car came back today with a multiple cyl misfire on all 4 cyls. I removed the Bosch plugs and they got me NGK plugs which I put in and test drove the car with no issues.
What is the difference between plugs if they crossover? What does NGK do different than Bosch or Champion vs AC Delco?
It's not like there are secrets in the plug world.
What was the source of info that the Bosch was supposed to set at 0.043 In a Audi. That sounds too large a gap for an Audi. Perfect for a Silverado.We have all seen it. Some engines don't like some plug brands.
AlldataWhat was the source of info that the Bosch was supposed to set at 0.043 In a Audi. That sounds too large a gap for an Audi. Perfect for a Silverado.
I can see how some may think that way, but remember it requires more energy for the spark to jump a bigger gap. The resistance of a spark plug, limits how much power goes thru the electrode, and jumps the gap to the ground side of the plug. You will have a crisper spark on a plug with a smaller gap. It will look more blueish. The wider you make the gap, it may look more orange. If you were to open the gap to 75-100 thousands, good chance you won't have any spark to jump the gap.,,The larger the gap (up to a reasonable limit) the stronger the spark. More voltage to jump= hotter spark
What Audi/engine?We have all seen it. Some engines don't like some plug brands.
And also the more potential for spark blow-out in forced induction applications. Typically as you turn up the boost the gap should get smaller and potentially the heat range should be colder.The larger the gap (up to a reasonable limit) the stronger the spark. More voltage to jump= hotter spark
I believe it was an 18,a4 with a 2.0.What Audi/engine?
Ya ButI don't order the parts. I just put them on.On the Sportwagen I've run (while having an aftermarket tune): OEM NGKs, OEM NGKs from another vehicle (1 range colder), Densos, NGK Rutheniums, and a current aftermarket plug that's 2 steps colder and is non-projected and gapped to 0.020" (OE gap is 0.028-0 030"). They all have felt exactly the same to me/no difference![]()
Wow, that gap on that plug is giant - alldata called for 0.04+ on gap? The gap on those Bosch's was just too big when you opened them up leading to the misfires, it had nothing to do with the brand I suspect. I bet those Bosch would have worked just fine installed as they came with the tighter gap, what I see is they are set to 0.027". Factory plugs are those NGKs and the ones I've measured were in the 0.03-0.032" range out of the box.I believe it was an 18,a4 with a 2.0.
I was one of the tuneup wizards in the Lowell, Ma, area in the 70's. Got a lot of mistakes and bad work from other area shops.We have all seen it. Some engines don't like some plug brands.
Makes perfect sense to me.My rule of thumb: replace the plugs with the same plugs that were installed at the factory.
I got a set of NGK copper for my 2006 5.7 hemi. Plugs were supposed to be gapped at .44, the .35 feeler would not go in. I opened every one of the sixteen a little bit until the .44 feeler would barely go in.We have all seen it. Some engines don't like some plug brands.
