- Joined
- Feb 4, 2025
- Messages
- 82
In some GM ecotec engines (z18xer), the coil packs seem to be very sensitive to spark gap. Too big of a gap or worn plugs kill the coil pack.
What does that even mean? Considering there aren’t any “copper” plugs, nearly all plugs have a copper conductor in the insulator and the differences come at the tip, cheap “copper” plugs are typically nickel.Saab had an anti-knock system that relied on copper spark plugs.
I read that GM used some of that technology on the Ecotec engines in Europe but I don't know about the US.
Ion knock sensors via spark plugs. That system is sensitive to spark plug type and gap. Here is some background to this neat technology:What does that even mean? Considering there aren’t any “copper” plugs, nearly all plugs have a copper conductor in the insulator and the differences come at the tip, cheap “copper” plugs are typically nickel.
So are you saying the anti-knock system relied on using one of the cheapest plugs available?
Well, that’s somewhat interesting but I still don’t see how it’s dependent upon tip material. Which again isn’t copper.Ion knock sensors via spark plugs. That system is sensitive to spark plug type and gap. Here is some background to this neat technology:
https://eeuroparts.com/blog/tech-corner-saab-trionic-and-ionization-sensing/
Regardless, there are advantages to copper spark plugs in some applications. Exotic spark plugs might be better for most of us for longevity, however.
How does that relate to the article that was linked?If you watched the firing lines on an oscilloscope you might see why.
Funny, I wasn’t the one that said something about oscilloscope traces. I thought perhaps you understood what you were saying.How do YOU you see it reacting/not relating?
Thanks. Yeah nearly all plugs have a copper core and a resistor. That’s where I was confused.Copper-core resistor plugs. Most ran recommended NGK''s, Platinum or regular was fine.
BCPR6ES-11 or 7ES depending on tune.
Knock detection was done between sparks.
I did read the article and I just didn’t see what the connection was.
Could you tell us more?- sounds very interestingIf you watched the firing lines on an oscilloscope you might see why.
Not speaking for anyone but you can graph misfires on a data stream and see which cylinder is misfiring and when. Or you can scope each cylinder, set your time base as such so to actually see the entire firing event on a scope ( oscilloscope). This is just a very small portion of advanced diagnostics needed for today's vehiclesCould you tell us more?- sounds very interesting
Thank you. I misunderstood your post- I thought you meant one could see the difference between Bosch and other brands on the scope.Not speaking for anyone but you can graph misfires on a data stream and see which cylinder is misfiring and when. Or you can scope each cylinder, set your time base as such so to actually see the entire firing event on a scope ( oscilloscope). This is just a very small portion of advanced diagnostics needed for today's vehicles
Exactly. Heat ranges, plug electrode material, . But yes essentially that's the differenceThank you. I misunderstood your post- I thought you meant one could see the difference between Bosch and other brands on the scope.
Just my experience, but I have used all sp brands in about 25 cars (and 4 motorcycles) and never had a problem. Don't understand what the problem is unless its due to heat range- one plug brand maybe a better match for the spec'd heat range
