Having chatted with a Nissan tech on another board on this VQ35DD thing, they may have stumbled upon the smoking gun in terms of the VQ35DDs they've found choked with sludge.
The PCV valve hose was found to be squishy, deformed or collapsed in some way on the sludged engines. As soon as you can, I would check this hose on your 2017.
Standing in front of the vehicle with the hood up, reach around the rear left corner of the engine (rear valve cover, left side). Feel for the PCV valve threaded into the cam cover. It threads in with a hex. You can trace it's hose where it routes and bends to where it connects to a stub on the intake manifold.
If you feel any soft spots, deformities on this hose, replace it. May as well replace the PCV valve while you're at it.
For engine oil/filters, I've been running various low cost 5w30 synthetic and low cost filters and changing them every 3500mi. Currently have ~83K on it.
