Vq35 and rotella 5w40
Tinley park il
Can shell rotella 5w40 be used in a 2004 vq35 altima with no issues? I can get this "diesel" oil for almost nothing. Will it hurt the cat converters at all? Thanks.
San Jose, CA (USA)
Worked great in my Infiniti QX4 which has the same engine--see the UOA forum for the UOA. The worry about cat pollution is significantly overblown, IMHO, unless your vehicle guzzles a quart every 3K or so. I've owned two VQ engines (I used to have a Maxima with a VQ30) and neither engine has used a measurable amount of oil, even with 7,500 mile OCIs. I think the chance of damaging the cat with these engines is virtually nil.
RI
Rotella-T synth is an API 'SL' oil. You require an SL oil. It won't hurt the catalytic converter any worse than any other 'SL' oil.
