I am a new poster here and I recently purchased a 2010 Volvo XC 60 with the 3.0 turbo motor. The owners manual calls for an A3/B4 oil spec. My question is, would a 0W40 with the later A5/B5 spec be acceptable or should I run a 0W30 with the A3/B4 spec? The manual shows a 0w40 is ok to run but I don't see where the A5/B5 spec is backward compatible with the A3/B4 spec and ACEA states that the newer A5/B5 oils may not be suitable for some engines.
