Our 2012 Chevy Volt is now 19 months old with over 22k on the odometer. The OLM is still at 76% and according to the computer the car should have consumed 111 gallons of gasoline. So on paper I should be good to go until the 24 months OCI that GM recommends. In the manual they state to go by the OLM or a 24 month maximum whichever comes first.
Then my oil change OCD set in. When you think of it, this should be the definition of severe service interval. In the 19 months the oil has gotten up to temp probably only a few times. Normally the engine is only on for a few minutes. On top of that it will come on and run at a higher RPM right off the bat depending on what mode it is in.
On the other hand does it really matter? At this rate the engine will consume less than a 1000 gallons of gasoline in 200,000 miles. This would equate to ~35,000 miles in a normal vehicle. It will also only consume about 27 gallons in the next five months at the current rate.
What say you? Should I change it now or wait until the 24 months are up? I do plan on getting a UOA on what comes out.
