After the results I got from an earlier VOA on this oil noted in an earlier thread https://bobistheoilguy.com/forums/threads/voa-rotella-t-syn-5w-40-ci-4-sh.80619/ I sent another sample to Blackstone.
It's RTS 5-40, CI-4+/SL rated.
RON: This 5W/40 oil from Shell looks perfect in our analysis. The TBN was 12.5, about as high as you see virgin oils go and it would read the same for their petroleum-based 15W/40. This is the synthetic form. We rarely see a problem with it though we do often see problems with other types of synthetics run in diesel engines. (my emphasis - wonder what that means?) For the purposes of this analysis though, we found no problems in this sample of unused oil.
MI/HR ON OIL:
MI/HR ON UNIT:
DATE: 1-21-08
ALUMINUM: 0
CHROMIUM: 0
IRON: 1
COPPER 0:
LEAD: 0
TIN: 0
MOLY: 0
NICKEL: 0
MANGANESE: 0
SILVER: 0
TITANIUM: 0
POTASSIUM: 0
BORON: 0
SILICON: 5
SODIUM: 2
CALCIUM: 3204
MAGNESIUM: 9
PHOSPHOROUS: 1249
ZINC: 1403
BARIUM: 0
SUS VISC. @210F: 75.4
Cst Visc. @100C: 14.37
Flashpoint: 425
Fuel %: —–
Antifreeze %: —–
Water %: 0.0
Insolubles %: 0.0
TBN: 12.5
TAN:
ISO Code:
Based on the unusual numbers in that earlier VOA, which about caused an infarction based on the zinc/phosphorous numbers, and the fact that we have it in a pile of expensive equipment, all I can figure is someone must have been in the garage playing with my oil jugs. That, or I worry too much.
MI/HR ON OIL:
MI/HR ON UNIT:
DATE: 1-21-08
ALUMINUM: 0
CHROMIUM: 0
IRON: 1
COPPER 0:
LEAD: 0
TIN: 0
MOLY: 0
NICKEL: 0
MANGANESE: 0
SILVER: 0
TITANIUM: 0
POTASSIUM: 0
BORON: 0
SILICON: 5
SODIUM: 2
CALCIUM: 3204
MAGNESIUM: 9
PHOSPHOROUS: 1249
ZINC: 1403
BARIUM: 0
Flashpoint: 425
Fuel %: —–
Antifreeze %: —–
Water %: 0.0
Insolubles %: 0.0
TBN: 12.5
TAN:
ISO Code:
