Originally Posted By: CATERHAM
Originally Posted By: edhackett
Actually, the Subaru manual does not recommend 5W30 for the use under which most people spun bearings. The manual(2003 WRX and 2008 LGT) clearly states that 5w30 is recommended for best fuel economy. For high temperatures and heavy duty use(that would include track days) they recommend thicker oils up to and including 10W-50 and 20W50. Nobody seems to actually RTFM and get past the required government CAFE brainwashing.
Ed
I don't see any "CAFE brainwashing" going on here.
AFAIK, CAFE requirements don't extend to track day use.
But it an incorrect interpretation of the RTFM to run a heavier oil intended for extreme use if you use you car primarily to get milk at the corner store and otherwise drive in a conservative manner as 99.999% of North Americans do, even those with sporty cars.
I know you talk about the "margin of error" but i think MOST drivers like an oil that can handle that "one time" they open their car up on an open highway, or take that surprise 10+hours trip to a family vacation with the grade of oil they selected.
I know you said its all about a "margin of error" and i can get my head around MOST of that (not all) before but then why does Subaru recommend a 40 or even a 50-grade based on heat, thats why i think OP said its a case of RTFM?
Also, warranty concerns. If not ENGINE LONGEVITY. Maybe the engine is a sludger and the engineers knew that and knew something we dont! Why, then, not.. do what they say.. oh you knew that was coming. Or a turbo. or has higher than normal engine temps like a ZR1 Corvette of the 90s, EVEN DURING NORMAL USE!! ?
I dont get this. heat DOES thin oil a la thicker grade used, then we say heat DOSNT thin oil i dont understand
Also should be noted car does NOT have OP gauge.................
Even BMW has Oil TEMP gauge not Oil PRESSURE gauge..............................................
So it is a mystery............................................
Thought the new Subaru engine spec'd a 20-weight............ a la CAFE brainwashing............. a la FORD......................................................
Need clarification.
