Originally Posted by slickoil
At 100 degrees C, why is Mobil 1 5W30 more viscous than their 10W30?
See
https://mobiloil.com/en/motor-oils/mobil-1/mobil-1
Higher viscosity index.
The 5w30's viscosity changes less with temperature, so it will tend to be thicker than the 10w30 at the hottest temps and thinner at the coldest temps.
OK. I'm officially confused. I thought a 5W30 acts like a 5W when it is cold, and like a 30W when it is hot. So wouldn't that mean it changes viscosity
more than a 10W30 due to temperature?
Also, which is the more important value to look at: Viscosity at 40 degrees C, or Viscosity at 100 degrees C?
Both are important. 40 tells you more about how it runs when it's cold; 100 is more relevant to how your engine will run when everything's up to temp.
Thanks. 40 is still fairly hot (takes my truck over 2 minutes to get that hot, according to the guage). Why don't oil companies routinely post specs for less than 40 Celsius?
Regular vehicle is a Prius, and it doesn't show engine temp on the display.
Don't Priuses take xW-20?
Ya, long story. It takes 0W20, but it's consuming oil, and several people recommended trying something thicker to see if that helps.
The 5W-xx means it passes the CCS and MRV requirements at -30C and -35C for the 5W Winter rating. The number in front of the W isn't the same as the number that comes after it.
