Possibly. If the thicker oil is also less volatile, that will help, too.
On the other hand, thicker oil is more prone to aeration, which can cause the oil level to rise as you drive. This usually isn't an issue but it can sometimes cause excess pressure in the crankcase, which can put more vapors through the PCV.
