It might interest you to know that our A320/319 (and soon to be 321) can, and DO, use an increased VR as a windshear precaution. I flew the jet for 6 years. I'm very familiar with the "Bus".
We do not use balanced field. Critical difference between us and others. We have our performance calculated based on everything you use, including CG, weight, runway, wind, altitude, temperature, slope, second segment climb, and probably a few things I can't remember.
So, for today's takeoff in EWR, we had the following takeoff data: 22R/W (intersection takeoff with 10,150 feet remaining) Flaps 5, reduced thrust, packs on, 215,800#, temp 21C, wind 283/19, altimeter 29.62, CG 28.5% MAC. Assumed temp for thrust reduction: 63C. That's a big reduction in actual thrust, but we still had plenty of margin with that thrust reduction.
V1 - 147
VR - 151
V2 - 154
VR Max (based on runway limit weight) - 164.
That's a 13 knot add we can use for increased VR as a windshear precaution. We still meet V1 stop requirements, and we meet every other takeoff consideration like second segment and obstacle clearance.
In Denver a few days ago, our increased VR was 18 knots above actual VR (I had stated V2, not VR in my previous post).
We had nearly the whole value of the reported loss added to VR before we left the runway. We had it covered. Had we not been able to add that much, and had we not carefully briefed our considerations and precautions (our mitigation plan) - then I would've refused to take off as well.
But we can add that much. We can take that much extra flying. Even on the Airbus. So, we did. At max power, with increased VR, on 34L at Denver, we rotated at the 8 board. We had 8,000 feet of runway remaining. I suspect that the only reason we couldn't add more to VR had to do with maximum tire speed, rather than a stopping consideration.
And we are not prohibited from taking off until we get to 30 knots, or microburst alert.
So, while I respect your decision to refuse the takeoff with the reported shear - the way we calculate performance, and our ability to add speed as a precaution, allowed me a safe, viable, option to be able to fly with the reported shear.
It wasn't a microburst, it was regular shear, and we flew right through it, while still climbing, because of that difference in how we approach performance.
