vibration when braking,replaced front rotors and pads,orignals had 55000 miles and still looked good. still has vibration when braking? could it be the rears?
If the vibration is still in the front, it's probably the ball joints and/or the wheel bearings. Also it is very much possible to buy a brand new set of rotors that are warped.
It's very likely the wheel bearings if you are feeling the vibration in the steering. I've heard of the sealed hub/bearing units on GMT800 trucks wearing out with relatively few miles. You should get way more than 55K miles out of the ball joints, but take a look at everything.
It could be the tires.Once had a truck that only vibrated during braking,inspected all usually suspects and found nothing.Tires needed replacing and afterwards the vibration was gone.
If the vibration is only while braking, the brakes a certainly suspect.
A worn suspension component will ALLOW vibrations to be felt and not be masked, but they do not cause the initial vibration.
Yes, it could be the rear brakes - whether drum or disc.
well, after driving today its more like a hopping sensation when applying brakes, dash/hood seem to move more now,kinda like bad balance. but it done this with old tires/brakes and still after replacing rotor,pads,tires. the suspension seems fine it only has 55000 miles
My parking brake cables froze in our record breaking cold. I had to drive the car, and it severely warped the drums.
Talk about vibration! Horrid!
New ones solved it [with my black Rustoleum finish!]
replaced rear rotors/pads. the pads were shot and not making full contact,rotors rusty. greased pins good and put back and now they are sticking,quess i will replace the calipers next
