So how do you know valvoline R&P did anything?Unfortunately, didn't take any pics prior. Bought this car used, I am not the first owner.
While the engine picture looks clean..
Not sure how you can declare its condition is from VRP?
Exactly what happened to me.An important thing learned from this VRP thread is before I thought of a clean internal engine without considering oil ring / piston ring carbon coking . *You can have an otherwise clean engine free of varnish and sludge - but if you have carbon coked up or stuck oil control rings then the longevity of the engine will be severely compromised unless action is taken to free up rings to do their job as originally intended .
Is that because they're full SAPS?I Have. Not until recently in this Accord, since I've only owned it since January. But in other vehicles, yes.
Chicago isn't cold enough to need anything more than a 5w, but I'd run a 0w anyway just to get better base oils.
The I'm only running 15w-40 because it's HPL 15w-40, and buying HPL is one of the few ways to ensure that the tighter number spread doesn't just give you really cheap base oils.
If I wasn't running HPL, I'd be running a 0w-40 Euro that's either Castrol Edge or M1 Euro FS.
INDEED. Not only can you have a surgically overhead with stuck piston rings, but you can also have pistons that are relatively OK with a completely nasty looking overhead. While I've posted some dramatic cleaning pics of the overhead of my Odyssey, I can't say that I've seen much change in consumption whatsoever-- this van never really used any noticeable amount even at 200k.Exactly what happened to me.
Prior to HPL and VRP that is what I thought LOL. I can't believe I was that dumb for all those years.An important thing learned from this VRP thread is before I thought of a clean internal engine without considering oil ring / piston ring carbon coking . *You can have an otherwise clean engine free of varnish and sludge - but if you have carbon coked up or stuck oil control rings then the longevity of the engine will be severely compromised unless action is taken to free up rings to do their job as originally intended .
Could be. I planned to pull the screen and verify when I replace the soleniods.
Exactly what happened to me too, and jammed rings happened early on my Hyundai. Go figure, “ It’s a Hyundai”.Exactly what happened to me.
