This will be boring or most as this is the a short run not pushing the envelope. I read the comment about the lube mixing, but I looked up a VOA of VRP 5w30 and the moly looked about the same to me. There was no Lube mixing beside what was left over from the change prior. This was the first run of VRP and I was just curious. Don't plan on testing again until the end of the 4th run of VRP. The initial fill was 4.4 QTs with an additional 0.6 QTs added as top off. The viscosity seems odd to me. Yes it has had some short tripping, but fuel dilution is low.
The only illogical answer I have, is VRP is so good at cleaning, that it took a lot of carbon out of our 200,000 mile plus engine, and kept it suspended in the oil so it was like thinner and stuff... that makes no sense right =P lol this last bit was a joke if not clear.
Insights and comments always appreciated.
