Just curious what Midas did. Was it a fluid exchange using the ATF cooler lines? Did they have the tool kit and know how to check proper level after?I got it in my '23 Frontier for past ~5k miles. Been shifting great. If it's suitable for the MB 236.17 spec, it works. Fyi, I did it at Midas where their system lists it as compatible. Also, did it as a flush. No pan or filter replacement @ 30k miles
I was more worried about it not having Matic p rating on a label.I'll vouch for Valvoline MaxLife ATF as I've used it for decades in countless vehicles and never had any issues. Very good product and trustworthy company. I'd skip Valvoline MaxLife and use Valvoline Restore and Protect ATF if I could get it (not in Canada yet).
The most important thing to a modern transmission is fluid temperature and cleanliness. Make sure to drop the pan and clean the magnets as they do most of the filtering and loose effectiveness as they load up. Add extras while you're in there if you can.
Interesting, I see what you mean (on the Valvoline MaxLife PDS). Give me a minute.I was more worried about it not having Matic p rating on a label.
How did you find that Valvoline Restore and Protect was P rated?Just looked over the Valvoline PDS for MaxLife vs Valvoline Restore and Protect ATF.
MaxLife ATF lists these Nissan specs:
Matic Fluid C,D,J,K,S,W
N-CVT
NS-1,2,2V,3
... whereas Valvoline Restore and Protect ATF lists these Nissan specs:
Fluid A
Matic Fluid C,D,J,K,P,R,S,W
N402
Viscosity looks almost identical, so I would expect the
I would contact Valvoline and see if they can provide details or see if you can find the Valvoline Restore and Protect ATF.
Are you out of warranty with your 2024 Titan? Nissan Matic-P is a greenish fluid. For warranty purposes, I'd avoid having a red ATF in this Jatco copy of a MB 9G-Tronic. If you're out of warranty, I'd have no issue using Maxlife or any other suitable for Matic-P use. There's been a few members over at a Frontier board I frequent who have used Maxlife ATF in their 9spd equipped Frontier. No problems.I was more worried about it not having Matic p rating on a label.
It's in the PDS (product data sheet).How did you find that Valvoline Restore and Protect was P rated?
And thank you!
