^^^ Yep, still need an ADBV to keep all the galleries full of oil, even if the filter is vertical with base up.
Oil from the valve train area drains directly into the sump, jack.
Not from the supply side if the ADBV is sealing correctly ... which is the side that counts, "Jack".
And the last time we saw an ABV which sealed well enough to keep the teaspoon of oil in the oil passages from draining was when, jacko?
Well, my brother's name is Jack (actually John, but he's been called Jack his whole life), & his '87 Tercel beater with the 3E 1.5 makes a pretty bad rattle with a Quaker State filter if the filter has more than 2K on it-it works just fine with a MC FL400S no matter how long it's on-does THAT COUNT??
