Originally Posted By: Colt
Originally Posted By: CATERHAM
Both my vehicles call for SN.
I have many qts of Toyota 0w20 SM.Most are red bottle.
I assume I can use the SM without any problem.
Am I correct?
Let's say Colt did use the 0W20 SM oil and something did happen to his engine, but it is uncertain that the oil caused it. What is the process in which the car manufacturer tries to determine if the oil was the culprit?
Colt, I am not trying to jinx you, I just want to know what is involved to get the results.
Utter fear mongering nonsense.
The difference between SM and SN oils is very subtle indeed, basically SN oils are a bit cleaner.
Amongst other reasons Honda will not for the reason I mentioned and Lexus will not because it is their own oil.
If Colt still had some doubts he could email the dealer or Toyota and ask if he can still use the SM TGMO 0W-20 that he still has.
More than likely,they really won't know and to play it safe will say they recommend SN.
I would tend to agree but I always here,"You better use what is spec'd for warranty reasons!" People must say that for a reason, and that's what I am trying to figure out. Has anyone actually had a factory run in with an oil issue?
Or, they heard it on the internet, because everything is true there.
