"1sttruck, I'm guessing that you believe if you continue to repeat these same fallacies of relevance over, and over, and over again, you're going to get someone to believe you?
In the spirit of providing BITOG members with knowledge that is actually useful, let me suggest you produce some real factual evidence minus the logical fallacies to support your position. Or maybe you can't, because there isn't any?"
Some inferences drawn from facts may be subtle, but there is nothing hard here. It is however impossible however to do so when blinded by what appears to be some sort of cult induced dogma, which seems to be the affliction of some 5w20 advocates.
Looking at some studies which seem to do a decent job of distinguishing between friction and wear vs viscosity, one finds that like the rest of the world knows, everything else being equal a higher viscosity tends to produce a thicker oil film, which results in lower wear. In some cases a thinner oil can flow better and produce a thicker film at some wear points, but thicker oils produce lower wear overall. Differences are less with well designed bearings at operating speed, more apparent at dead center of piston strokes, and in some valve trains. Gears favor heavier oils, and one can assume that chains do too.
http://www.iantaylor.org.uk/papers/friction.pdf
The Piston Ring Contact (cont.) - Highest loads occur close to dead centre positions, and although speeds are low, "dwell times" are high. (chart shows higher wear for lower viscosity).
Valve Train Lubrication - Frequently the most difficult engine component to lubricate: thin oil films, high loads.
http://www.iantaylor.org.uk/papers/piston2005.pdf
Oil film thickness measurements - in general higher viscosity oils give thicker films. However, top ring film thickness could be thicker for lower viscosity oils.
http://gltrs.grc.nasa.gov/cgi-bin/GLTRS/browse.pl?2005/TM-2005-213956.html
ABSTRACT:
The influence of lubricant viscosity and additives on the average wear rate of spur gear pairs was investigated experimentally. The gear specimens of a comprehensive gear durability test program that made use of seven lubricants covering a range of viscosities were examined to measure gear tooth wear. The measured wear was related to the as-manufactured surface roughness, the elastohydrodynamic film thickness, and the experimentally determined contact fatigue lives of the same specimens. In general, the wear rate was found to be inversely proportional to the viscosity of the lubricant and to the lambda ratio (also sometimes called the specific film thickness). The data also show an exponential trend between the average wear rates and the surface fatigue lives. Lubricants with similar viscosities but differing additives and compositions had somewhat differing gear surface fatigue lives and wear rates.
