I am interested in getting either a Franz or Motor Guard TP bypass filter and I want to use it with an AMSOIL AMK02 pre-oiler. I was planning on installing a bypass filter with a tee fitting at the oil sending unit. Then I saw the AMK02 and wanted one (I didn't like the tank per-oilers that I also saw). I don't think it would be a good idea to install both at the oil sending unit. It might be better to install the AMK02 at the oil sending unit and the bypass else where. But I am not sure where. I really don't want to install an adapter at the present oil filter location to feed the bypass. The intended car is a 2007 Suburban 5.3L (Gas/E85).
Any suggestions?
Thanks.
Any suggestions?
Thanks.
