USAF - C17
NJ
"Pentagon: U.S. can get up to 30 C-17 evacuation flights out of Afghanistan each day.
16,000 people evacuated in the last 24 hours, about 11,000 of those on military flights.
Have you ever seen a C-17? I know most of my fellow aviation nuts have, but for my friends/family who have not, that is a HUGE aircraft. Absolutely immense. And the USAF is cranking out a full C-17 flight from Kabul every 45 minutes, using a SINGLE runway in enemy-controlled territory, non stop, 24 hours a day right now. This has literally never been done before in the entire history of aviation... the USAF is literally making history. They evacuated more than twice as many people YESTERDAY as we did in the entirety of the Saigon evacuation in 1975.
It started rough, no denying that, but in less than a week, the situation has been stabilized and the mission exponentially increased to a tempo never before seen, not even during WW2. The part that gets me is the logistics of supporting this mission - the ground crews are going full throttle right now, bringing in fuel, oil, fluids and servicing the aircraft as best and as fast as they can. What they are achieving right now is nothing short of incredible."
Jumped out of C17s many times. C17s can take off and land on runways, but also on dirt strips. A very nice cargo aircraft.
If memory is correct, they are only based out of Charleston AFB and McCord AFB. They were manufactured in Long Beach, CA. That assembly line was shut down last decade. Tough plane to replace if/ when there are losses.
Note: I watched a movie on TV called The Big Lift. Filmed in post war Berlin. Interesting scenes of civilians picking up rubble, putting into hand pushed carts from the structure's bombed during WW II. Worth watching if you've never seen it.
You jumped out of a perfectly good C17 !!!???? I won't be messing with you.
LOL!!! I can't even intimidate my three year old Grandson to put down a water balloon.
We loved jumping the C17s, SO much room, felt like we were flying in a Cadillac limo, when compared to the C130s which felt like 55 guys packed into a Ford Escort.
Well - I'd say it's not that big. A C-5, KC-10, or even C-141 is bigger. It's really, really chunky, and that was intentional so that they fit helicopters. The requirements were insane. They wanted something bigger that could land at the same makeshift or damaged airports that a C-130 could land on, but with much faster speed and much higher capacity.
Friend of mine is a C-17 Loadmaster out of Charlotte
I'm pretty sure they're based all over the world. I guess it's complicated what they consider the home base. But there are several at Travis AFB in Fairfield, CA which moves more cargo and passengers than any other US military installation. I saw this one in a movie:
Wingspan and length are just under the 767-300. Big, but not like a 777-300 or a 747. Mid size, really.
But it is chubby. A fat fuselage for good load capacity.
Relatively heavy, at a max of 580,000, which puts it above a 767-300 at 407,000 or a 767-400 at 450,000 but well below the 747-400 at 875,000 or the 747-8 at 975,000, let alone the A-380 at 1,200,000.
Those who have flown it love it. Great handling. Capable. Modern. A good jet. The austere field capability is impressive based on size, but it’s so heavy that the number of fields are limited by the weight.
A C-5 has a lower landing gear loading and while bigger, can land on fields with lower reinforcement/strength specifications.
Neither airframe has been risked in the truly austere locations that are the C-130s forte.
The C-141 is not larger than the Globemaster.
C141 & C17
