Hermann
Site Donor 2023
And 96% of folks leave them that way, sadly. Mine has a lot of stuff disabled and tighter security enabled.Only if you leave your phone on factory default settings.
My main concern is I have Amazon but I do use them, like they use me, only when needed.
But why are people ok with helping Amazon make more money by allowing their devices to use your internet connection?
Yep … when I get a new company iPhone … have to go through a procedure where it becomes managed by IT and only approved apps allowed …And 96% of folks leave them that way, sadly. Mine has a lot of stuff disabled and tighter security enabled.
Agree . The Fios tech came today to install/replace my optical terminal network OTN and I asked him how many residential fios customers use an entire household vpn connection for personal use. He said very few.And 96% of folks leave them that way, sadly. Mine has a lot of stuff disabled and tighter security enabled.
The good news is, there is no problem in my house, no Amazon connected devices. (almost)Because you never know, someday you may use them instead of they use you (say to diagnose your internet has crashed or you need an E911 call but someone cut your internet).
Seriously sharing internet isn't the big deal, leaving an entrance for others to hack into my wifi is the bigger problem. What if they find a way to pretend to be an Alexa and then get into my Alexa and then into my guest wifi?
I am curious about the "security issue" or is the that the click bait headline? I am ecstatic that Xfinity has their Xfinity Wifi in over 1 million hotspots in businesses and homes rental routers. It just works really well.You should be aware that Amazon is about to start sharing your wifi with others using their devices.
Here’s the article that was passed on to me about the Amazon devices, including Ring security devices, being involved.
https://arstechnica.com/gadgets/202...lly-share-your-internet-with-neighbors/?amp=1
Ed
Security is not an issue. YOU can let your neighbors access your wi-fi network all you want so they can run their Amazon devices reliably.I am curious about the "security issue" or is the that the click bait headline? I am ecstatic that Xfinity has their Xfinity Wifi in over 1 million hotspots in businesses and homes rental routers. It just works really well.
In theory, if the is no security problem in Alexa, it is not a problem. In practice we typically have lots of bugs in software that we don't step on and if one intentionally look for, and since Alexa can bounce to another neighbor's wifi in low bandwidth mode (likely for diagnostic of network issue), then there is a possibility that someone can spoof an Alexa, and have it sent out a request to its router and the packet get intercepted, then by some "bugs" or "calculations" they can figure out the wifi password.I am curious about the "security issue" or is the that the click bait headline? I am ecstatic that Xfinity has their Xfinity Wifi in over 1 million hotspots in businesses and homes rental routers. It just works really well.
This is a good practice, all IoT devices should be on a separate wifi network with different password.Seems like too much worry. Just put your IOT devices on a segregated VLAN or isolated wifi network and let them get to the internet but not back to the internal network. Pretty much end of story.
If an amazon device wants to use a few bits for someone else let them do that. If you have a ROKU device, you probably don't know that ROKU is an advertising company, and that thing is constantly phoning home. It is much more chatty than anything I have from Amazon.
You are stretching this. Your neighbors aren't talking to your WiFi network directly, i.e. if you check your router's list of connected devices, it will only be your own. This is presuming your router has security set up, of course, so your WiFi network is just as secure and locked down as it was with or without Amazon devices.I find this outrageous, Amazon will be using your wifi for their devices in other peoples homes.
The executive I work under at my Tech employer had incessant wifi connectivity issues with her ISP provided Mesh system in her home. The issue ended up being an IoT outside her home that was flooding her system with Wifi connection requests and causing her poor wifi. Her ISP blocked this IoT somehow.This is a good practice, all IoT devices should be on a separate wifi network with different password.
Yeah I agree but moving forward buying one of their devices you are agreeing to it unless you turn it off.I don't mind turning it off, but giving them bandwidth I pay for? That's theft.
