Originally Posted By: Hyde244
^ And they also spec thread-end bypass valves for filters that are perpendicular to the ground, such as the Ford Focus.
I know someone on the forums has actually tested PSI of oil filters - would appreciate it if someone were able to drag up the link for that thread.
In general, longest time a bypass valve has been shown to operate in normal operation is during a cold start-up. Of course the valve will open if you go full throttle, but anything above 5,500 RPMs would hardly be normal operation.
That would be our member Jim Allen, you can search for his threads.
The filter's bypass valve should not open at red line if the oil is at full operating temperature (ie, ~200 deg F). High revs with cold oil, probably so.
