2001 Crown Victoria LX
Miles on car: ~21,000
Miles on oil: ~5,100
Make-up oil: None
Filter: Mobil 1
Oil was used between April 1 and June 6 in NYC weather. "Enthusiastic driving"
As Tested Average
Aluminum 3 5
Chromium 1 1
Iron 14 22
Copper 3 11
Lead 1 2
Tin 0 1
Molybdenum 76 31
Nickel 0 1
Manganese 1 1
Silver 0 0
Titanium 0 0
Potassium 3 0
Boron 143 45
Silicon 26 13
Sodium 8 7
Calcium 2756 1768
Magnesium 35 450
Phosphorus 775 787
Zinc 874 971
Barium 0 1
SUS @ 210F 60.6 55-62
Flashpoint 420 >365
%Fuel %Antifreeze 0.0 0
%Water 0.0 %Insolubles 0.2 TBN 4
Comments:
Silicon was the only unusual find in this oil. This may be from dirt getting past the air filter, though some types of spray lubricants or oil additives will also cause the silicon level to read high. All metals were well within the normal range. Universal averages column shows typical wear from this type of engine after about 4,300 miles on the oil. No fuel dilution or anti-freeze was present. If your air filter looks good, we would not worry about the silicon too much. The TBN reat 4.0, so the oil still has some life left. Suggest going 6,000 - 7,000 on the next oil.
My comments:
I would like to go a little longer on the oil, but I don't want to go through the trouble of
changing the oil filter between oil changes. I always use a Mobil 1 oil filter. Would 6K or 7K be accepptable with a Mobil 1 oil filter?
[ June 26, 2003, 12:19 AM: Message edited by: johnicon ]
Make-up oil: None
Filter: Mobil 1
As Tested Average
Aluminum 3 5
Chromium 1 1
Iron 14 22
Copper 3 11
Lead 1 2
Tin 0 1
Molybdenum 76 31
Nickel 0 1
Manganese 1 1
Silver 0 0
Titanium 0 0
Potassium 3 0
Boron 143 45
Silicon 26 13
Sodium 8 7
Calcium 2756 1768
Magnesium 35 450
Phosphorus 775 787
Zinc 874 971
Barium 0 1
Flashpoint 420 >365
Comments:
My comments:
