Hello guys, I am having a misfire on cylinder 5 that I can't seem to get away from at all.
The P0305 code is not making a light on the gauge (it's pending) but I can still scan for it and slightly feel it at idle.
Vehicle: 2014 Chevy Suburban (Vin "0").
What I tried:
I replaced the head gasket some months ago, and one of the top small head bolts snapped due to a faulty torque wrench... I have yet to deal with it as my compression/head gasket are seemingly fine.
I pulled the spark plugs from cylinder 1 (left) and cylinder 5 (right). I did notice a small amount of oil on the last couple of threads of the cylinder 5 plug, could that mean something?
Took the valve cover off and inspected the push rods, something is definitely weird with the cylinder 5 intake push rod. It looks like it has this orange scratchy appearance on the end that is closest to the camshaft. I haven't been able to find anything about this online at all, no idea what this is. Anyone ever seen something like this?
Images push rod order (left to right): Intake 1, exhaust 1, intake 3, exhaust 3, intake 5, exhaust 5.
Another angle of the same ends:
What I tried:
- Moving the spark plug to a different cylinder (didn't do anything)
- Moving coil and boot to a different cylinder and replacing said coil/boot (didn't do anything)
- Replacing fuel injector (didn't do anything)
- Compression test (good compression)
- Head gasket leak test (no leak)
