High Temperature High Shear viscosity is a (the most?) important specification for each oil viscosity. But I’m not sure how it relates to everyday engine protection.
Using 20 weight oil as an example, my understanding is:
* 100C viscosity should be in the range of 6.9-9.2 cSt
* HTHS must be at least 2.6 cP @ 150C
* cP and cSt are related, but cST is not density-adjusted and is about 15% higher than cP, making 2.6 cP roughly 3.0cSt
I realize oils in passenger cars are unlikely to reach 150C except for very short period around piston rings, but this spec is there for a reason. Does this mean that an engine spec’d for 20 weigh oil would happily survive with a sump full of 3.0 cSt oil? Or is it only a spec relevant to very brief exposures to very high temperature conditions in very limited areas where lubrication needs are different?
For those of us that panic when a UOA where our 20-weight oil’s viscosity has been sheared or diluted out-of-grade to a 6.0 cSt, this seems an important spec to understand.
Thanks for comments.
