UGH... Mobil 1 15w50
Colorado
Ok... before lovers start to respond.... I love Mobil 1 15w50. Before haters respond... I also hate Mobil 1 15w50.
Let me explain.....
I know this oil is beloved by the BMW crew. It is frickin awesome oil.... But I am learning, there are times NOT to use it.
Case in point.... My newly purchased BMW R1100R with low mileage.
After purchasing, I dumped all lubes. Then I poured back in... Rotella T4 15w40 conventional. The bike ran perfect...
Then after about 500 miles, I decided to dump the cheap Rotella and pour in some liquid GOLD.... Mobil 1 15w50.
Frick... within 200 miles, I have oil leaks and seeps on the engine. On start-up, the engine has some weird squealing noises that totally concern me.
Tomorrow I am dumping $26 of oil..... and going back to Rotella T4 15w40 Conventional.
I experienced a similar issue with my hexhead. The rear main seal leaked with Mobil 1 15w-50 but not with conventional oil.
How many miles are on the R1100R?
I know people on this forum in general will mostly disagree that one oil within a certain spec will leak while others won't, but I've experienced this same thing in an older car, twice, once with Mobil 1 5w30 and once with Mobil 1 10W-40 High Mileage. Engine didnt leak oil, then switched to Mobil 1, started leaking almost instantly. Switched back away from Mobil 1, leaking went away.
I really like Mobil 1 for newer vehicles, but in anything older I won't use it anymore. Again, people will say "that can't be right", but there has to be something (in my opinion) about how they formulate their oils that causes this.
I have an R1200R with 66,000 miles. No leaks or squeaks with Mobil 1 15W-50.
Did you wash that bike? Water on the alternator belt makes a horrible squeal. It will go away quickly….or just let the bike dry for a few hours.
bac in the day before the Castrol SCAM mobil I 15-50 was a high quality PAO prolly with ester as needed, today not so much as it was reformulated like others using cheeper group III oils that became legally marketed as "synthetic"!!!
Mobil 1 was still using PAO in certain oils pretty recently, years after the Castrol deal. Mobil 1 Extended Performance had a good amount of PAO until like a year and a half ago when they switched to GTL. M1 V-Twin apparently still has PAO.
