Originally Posted By: SAJEFFC
Well that may very well be but this heat has gotta be tough on oil.
Why? Better engine oils typically don't start suffering thermal damage until the high 200s (farenheit), which is much hotter than your engine probably sees even in this heat. Higher temps are probably
easier on the oil in that they more quickly drive off water, fuel, and other contaminants that can lead to acid formation. Oils with high volatility might have problems.
I am amazed though that you very seldom see cars on the side of the road anymore with the hood up and overheating. Cooling systems have sure come a long way.
Like oil, I think coolants have come a lot further than cooling systems for the most part. Radiators plugged with corrosion by-products are what used to cause overheating. Modern antifreezes (well, except DexCool
) just don't gunk up radiators like the older ones did. I've got two old 60s cars, one with a stone stock cooling system except for modern antifreeze. No problems in the current 104+ daily heat. One of these same cars used to routinely have to have the radiator rodded out "back in the day" but never anymore. Don't know about the other one, I've only owned it since '94.
Yes, electric fans on modern cooling systems are a big help in city traffic, though. One of my oldies has a pair of pusher fans for the R-134a converted AC, and it's temp never budges in traffic, whereas the other one with just the engine-driven fan heats up about 10-15 degrees from where it runs on the freeway on a 100+ degree day.
