Two different CarQuest R84356s
NY
We recently purchased a CR-V, and while ordering some maintenance bits I saw the discounted "Famous Maker" filters on Rock Auto. Figured I would get a bunch of them to stock up given the generally favorable reviews here.
Since I got a bunch of them, I noticed some looked a little different. All have the "leak tested" on the top, so they are the PG filters. But turns out I have a few of them that are from the Vietnam factory, while the rest are from China.
The can is shaped a little differently, the holder (not sure of the correct terminology) for the spring is different, and the Vietnam ones have what looks to be excess/sloppier glue.
I don't have the tools for a proper cut, so outside shots only at this point.
Has anyone else seen these differences in the same CarQuest reds before?
The can is shaped a little differently, the holder (not sure of the correct terminology) for the spring is different …
Sounds like you're talking about the bypass valve configuration.
