Originally Posted By: aquariuscsm
Originally Posted By: BrocLuno
There is a lot to a stylus. In fact it is 1/2 of teh sound equation of the cartridge. The suspension is very important for tracking. But the cut of the diamond and the bond (nude or glued) is also very important.
If you like the sound you have, I'd stay in the Audio Technica line. They are all pretty neutral, but you might step up a notch in the food chain...
Will there be a difference between a $7 copy and and a better copy - Yes. A company in Japan (Jico) makes first class replacement styli. In some cases they are better than OEM. But, I'd start out at AT and see what you can find ...
http://www.lpgear.com/
http://www.needledoctor.com/
Use this site to see which physical styli carrier you use:
http://stereoneedles.com/audio-technica.html
The Jico looks to be a very good one. Got excellent reviews.
I compared my two turntables side by side playing the same record,a mono pressing of The West Coast Pop Art Experimental Band Vol 2 (US Reprise mono). One turntable has a Shure and the other has the Audio Technica. The Audio Technica sounds more clear and sharp,and I heard cymbals in the music that were not present with the Shure,almost as if I was hearing "more of the band". Also less vinyl noise as well. I'm guessing maybe the Audio Technica either tracks better,or has better frequency response. Both turntables are set at the exact same tracking force too. Stylus on the Shure is an elliptical whereas the Audio Technica is a conical.
In general Audio Technica tends to have a brighter, crisper sound. The Shure house sound is warmer and a little rolled off at the top end. Interestingly, both companies also follow this trend through their lines of headphones. Generally, audiophiles usually don't like both brands, but prefer one over the other. I'm a big AT fan myself,Shure products generally sound dull to me.
