Originally Posted by Uphill_Both_Ways
I wonder if a driving test would be cancelled if the car was a pre-'53 without turn signals and of course no seat belts. No turn signals would be ideal for the OP.
What if it were a pre-electric-start car such as a Model T and had only one tail light, perhaps legal because that was how it was built? Would the person being tested fail for tucking his/her thumb around the crank handle and/or right-hand cranking?
Really you don't know the answer to this? You cannot take the driving test if the vehicle does not have mandatory equipment. It would be illegal to drive if you had a license and cannot be licensed itself. You can literally get a ticket for driving it for every offense.
Quote
And the car is so old it was built with no windshield wipers, has to back up a steep hill because the gas is gravity-fed, has only a hand throttle and rear-wheel-only mechanical brakes.
Consult your state as to the requirement for wipers if it's not raining. Otherwise, you're getting silly as none of that pertains to required equipment.
In many states these 25+ year old vehicles have a special license plate that only allows driving in parades or other special events, or to and from the (nearest) gas station.
What many people here are not understanding is you don't only have to signal, you also have to do it a certain distance before changing lanes or turning. This distance maybe as short as 50 feet but can be 100ft, even 200ft in some states. I wouldn't expect an officer to give you a ticket if no other vehicles are around, usually not stop you at all (has better things to do) but if one wants a reason to pull you over and to see what falls out of it, don't be surprised.
