Originally Posted By: lui
Originally Posted By: lancerplayer
Would Shell Rotella T6 5w40 fit the bill?
that's what im using now. and i was using Royal Purple before that. hard to say how the turbo is holding up without taking it apart but it's been on the car for 4-5 years and it's still kicking. recently pumped 440+hp on the dyno.
i have an oil temp gauge installed....believe me....it take at least 10min of idling for the temp to drop from over 210F to under 190F which is still very hot...and trust me the shaft of the turbo is gonna be much hotter than that.
the 1min of idle time makes no sense to me...if anything the radiant heat from stopping air flow from moving actually make it hotter under the hood and in the engine.
use a good oil and you wont have an issue..
Rotella T6, Royal Purple, Amsoil, Redline, Mobil 1 will all work really well.
We're not talking bulk oil temps, we're talking about the shaft. EGTs are what you want to watch. The shaft heats up quickly, and cools quickly. You want the oil to carry this heat away.
Stopping airflow? Exhaust is always moving through the turbo. We're talking about the shaft, not the engine and not the housing. At idle this air (exhaust) is much cooler than when the engine is under load.
