The Defender LTX Platinum is Michelin's Highway All-Season tire for the drivers of premium heavy-duty light-trucks. Designed to deliver a quiet, smooth ride with Michelin's notable craftsmanship, the Defender LTX Platinum blends striking aesthetics with year-round traction in dry, wet and even light snow.
Defender LTX Platinum tires bring a number of the latest Michelin technologies forward, including Evertread 2.0 compound, specifically formulated to resist abrasion under high load and high torque. This next-generation compound is molded into a symmetric tread built to maximize dry grip alongside Michelin's MaxTouch 2.0 Technology: optimized for each individual tire size in the Defender LTX Platinum lineup to evenly distribute stress in the contact patch, maximizing tread life and reducing uneven wear. Each of the three central grooves is molded with a widening channel running through it to allow efficient water evacuation while still maintaining surface contact over damp surfaces for the tire's usable lifespan. Thanks to the generous usage of wavy and lateral siping in the Defender LTX Platinum, it has the biting edges needed for all-season traction.
The internal construction of the Defender LTX Platinum contains a dual ply polyester casing supporting two steel belts. A polyamide reinforcement cap ply aids in handling performance and provides high-speed durability.
3D siping is for hydroplane resistance and in some cases improved snow performance.
Fixed it for youI don't know anything about these tires but that's pretty cool on a utility trailer
Siping and 3D siping are kinda different things. 3D siping effectively creates more void space by allowing water to flow into different areas in the tread.hydroplane resistance is a function of tread void area and design.. how does siping increase it? And you are claiming hydroplaning resistance is the primary purpose of siping?
AFAIK.Siping and 3D siping are kinda different things. 3D siping effectively creates more void space by allowing water to flow into different areas in the tread.
It’s not a very well defined term. It just means there’s 3-dimensional cuts and voids in the tire that enhance various performance characteristics.
It’s semantics based on what you consider a “3D sipe.” In some cases they are just gouges or voids on the side of a tread block, like in Michelin Pilot Road motorcycle tires, used for hydroplaning resistance. In others, like in the video above, they are holes between tread block voids, again likely used to maintain hydroplaning resistance. In yet others, like in the Nokian Outposts, they are interlocking “legos” between tread blocks and “steps” adjacent to them to improve stability and snow traction.AFAIK.
It is more for snow and wet traction not hydroplaning resistance.
Which is why there is a ton of it on winter tires such as blizzacks. The main point of the "3d" is the tread blocks arent as floppy/mushy vs regular sipes
so that's why there are so many 3d sipes on summer tires that have some of the best wet traction and hydroplaning resistance?It’s semantics based on what you consider a “3D sipe.” In some cases they are just gouges or voids on the side of a tread block, like in Michelin Pilot Road motorcycle tires, used for hydroplaning resistance. In others, like in the video above, they are holes between tread block voids, again likely used to maintain hydroplaning resistance. In yet others, like in the Nokian Outposts, they are interlocking “legos” between tread blocks and “steps” adjacent to them to improve stability and snow traction.
The point is that there are newer ways of designing treads that use 3d geometry to improve traction in various conditions.
You’re being hyperbolic but I would not be surprised if the sides of tread blocks in these applications have scallops out of them if you look hard enough.so that's why there are so many 3d sipes on summer tires that have some of the best wet traction and hydroplaning resistance?
