JHZR2
Staff member
Quote:
Did I have transmission problems? Yes, I did. The transmission, manufactured by Aisan, blew at 53,000 miles.
It wasn't Toyota's fault but Toyota stepped up to the plate and replaced it at no charge, even covering the rental car for three days.
So if it was not toyota's faut, then whose fault was it? Yours? did you maintain it poorly? Do you drive too hard? Seems to me that the transmission in a relatively heavy truck that is built to be tough should last longer than 53k regardless, unless either you did something really stupid or Toyota sourced a really lousy part.
I find it humerous that a domestic has a failure and are labeled 'bean counter driven' and 'unreliable', whereas a toyota has a failure and it is claimed that it 'isn't their fault'. Sheds perfect light upon the double standard. This double standard goes directly back to the reality that is maintenance - people buy the toyota serivce packages at the dealer without battin a n eyelid... they go to their chevy dealer and feel that they are being ripped off for a coolant flush after 3 years. I wonder which vehicle will proviudebetter lifecycle utility, if one is maintained to a 't' and the other is marginally maintained by the lowest bidder...
Unfortunately double standards abound. Good for Toyota if they fix the issues and provide a high level of service when doing it - great, that is why people pay a premium for the toyota vehicle versus an equivalent domestic. That's A-OK... but let's not overlook the double standard and let's get rid of the concept that toyota is faultless... good on you for claimint Toyota's fault for braking system issues, which they fixed - but at 45k miles, the OE should darn well fix such a critical safety system for free, whould there be the slightest issue - obviously they messed up bigtime in their estimation of design needs to let something hit market with such a poor setup. Yet some think its no bog deal... heaven forbid that ford did this - people would think that Bill Ford himself was out to kill them... but toyota fixed it, gee, theyre swell...
There is a major difference between poor engineering and after-sale serivce level.
JMH
